WTB: [Searching] S15 rear subframe
B
BH1
Hi guys,
im looking for a rear S15 Subframe without arms, diff and anything else. I just need the subframe.
Looking forward for offers by PM.
Greets
BH
Where are you?
Not that i have one spare, but may help if you state where your at.
isn't it the same as the S14 one?
Wouldn't count on it. It'll be similar but here's a quote from Phil Morrison of Driftworks...
The rear subframe is noted to be massively superior to the S13 and S14 items. I haven't pulled it off to compair yet, but to give you an idea, check this brace between the 2 rearmost mounting points:
B
BH1
Where are you?
First thanks for all the replys.
I'm located in Germany but i would take care of shipping costs if you could source me one. :wave:
The S15 subframe is not the same as the S14 one, its much better. :thumbs:
Derek
Did it crack on you?? Whats part number on subframe lads?
Part Number:55400-85F01-
Description:MEMBER COMPL-REAR SUSPENSION
Prod.M/Y:9901-0007
Part Number:55400-85F00-
Prod.M/Y:0007-
B
BH1
Prod.M/Y:9901-0007
Prod.M/Y:0007-
Thank you for this information am i right that the first part number is for models from 01 '99 to 07 '99 and the second part number is for models above 07. '99 ? Or am i completly wrong ? :wack:
I thought someone could supply me with an used one but if not i have to order directly from Japan i think.
The first one is Jan 1999 to July 2000. The second is July 2000 onwards. I have no idea what the difference is.
The subframe will see out the life of the car, so its unlikely anyone would change it. You could try a salvage company which stocks S15s. http://www.euroautosalvage.co.uk :)
B
BH1
Thanks for the reply, i'm just curious are these the complete part numbers or are there a few letters /digits missing.
They are the full numbers as listed in FAST (Nissan's parts database). The listings I gave were cut and paste from FAST.
They are just the subframes. No bushes, bolts, etc.
24 February 2006
Plymouth
I had mine off to spray and fit poly bushes... didnt compare it to the S14a one next to each other but from what ive seen there is sod all difference... it might be worth getting hold of an S14 one second hand if you could get one for pennies and trial fit it...
Just checked FAST. There were three different S14/a subframe part numbers. All three are completely different to the S15 part numbers.
Derek
@bh1 why you need it?
B
BH1
First you can't use an S14 subframe on an S15 but you can maybe use an S13 subframe on a S15. The S15 is the best subframe you can get for Rwd-Nissans, its better then the S14 one and much better then the S13 one.
I do need this subframe for my S13 as an upgrade. :wave:
