CLUTCH PROBLEM!! Help me please.!
N
nicks15
Hey guys.. this has happed to me 2 time before about a week ago.. i go in my car warmed it up went to put in Revers and it didn't go in.. none of them did , i pumped the clutch... for ages and still nothing.. it was like somthing ws stoping it from going in.
i finally go the gears in and drove to work, but every gear was really hard to get in.. drove fine it was just that, by the time i got to work it was normal?
what is the promlem ?
PS..... I have a Hi tourq heavey duty clutch just put in 2000 Km ago.
please help me out.!
Try bleeding the clutch and clutch slave.
Sounds like the clutch mechanism isn't doing it's job properly. Check master and slave cylinder for leaks.
I haven't bleed my clutch yet, but I've read is a total bitch with the clutch damper lines in place. So I would look into removing the clutch damper line and replace it with a steel braided hose and retry the bleeding process.
Could also be the clutch pedal which is out of tune for some reason. If the biting point is to low, the clutch might not fully engage as the floor is in the way. There should be a guide in the workshop manual how to set the clutch pedal.
there could also be a leak in the clutch hydraulics somewhere.
