Spec R and Spec S brake rotors
17 March 2009
I'm buying EBC brake pads for my Spec S, and I'm a bit concern that do these pad fit into my Spec S brake caliper as in EBC brakes website, it stats that their pads are available for S15 Turbo model only, so i'm just wondering whether they would fit?
I know that Spec R has 4 pots brake caliper and Spec S only runs 2 pot
Thanks guys
Oh
its cheap enough to just get a set of Spec R front calipers as they bolt straight on then put those pads in and have way way better braking then the S
Trial_S15
13 July 2008
Meath, Ireland
www.modifiedmotors.ie
x2, I swapped out mine for a set off of a 2001 UKDM 200sx & the difference was amazing, you will need to alter the dust guard & get new discs but you should get them cheap with the calipers :thumbs:
I went for a complete brake upgrade (calipers, discs, pads & lines front & rear) and bought S14a lines for my S14a calipers but they were too short so get S15 ones if you're considering doing the same :nod:
6 April 2009
ireland
Stupid question but i presume the spec s lines will be a straight fit to the turbo 4 pots?
Toby
I thought Spec S + R's had the same brakes anyway?
6 April 2009
ireland
Spec s is 2 pot, spec r is 4, same rears i think.
Toby
I see!
A very worthwhile Upgrade for Spec S owners then, (must be a right pig to find pads for them).
6 April 2009
ireland
I see!
Thats what im after doing, got s14a 4 pots and discs, and just been told the 2 pots are the same as on s13's so they are probably an easier order.
