Urgent! Dual mass flywheel skimming help!
Havoc
27 March 2010
Portsmouth
Hello!
I'm getting my dual mass fly wheel skimmed and the guy doing it doesn't want to touch it untill he knows if it suppose to V tp the flat surface evenly from the centre and outer edge of the flywheel! Pr if its suppose p
Be flat across the whole surface.
Because in order for it to be flat the whole way across
He would have to take a 1/4 of a inch of it and the angled edges seemto
Be evenly cut not worn differently.
I.e should the surface be flat or should it V fom each edge to a flat surface??
Cheers!
28 July 2009
They need to knock out the dowel pins and skim the whole face flat. Most people won't touch dual-mass flywheels as they're a pain to mount onto the lathe, it took me ages to find a place that would do mine.
Havoc
27 March 2010
Portsmouth
Cheers! I just went for it in theemd and yes just took the dowls out! You not had any problems with yours at all?
28 July 2009
Nope I didn't have any problems at all with mine. As long as they know what they're doing and skim it perfectly flat you will be fine.
if you get stuck i have one i no longer need ;)
