FS: 2 x aftermarket sumps, replica Aero bumper, carbon heat shield
Max
31 October 2010
Cornwall
Mini garage clearout to raise funds.
Greddy replica cast aluminium SR20DET sump. Small leak from one of the through bolt holes. (the one with the red sealant on) Surely can be repaired easily. Sensor and valve not included, 4 x long allen bolts included. £35 posted
Canton SR20DET sump. Amazing quality, don't really want to sell but for the right money I cant say no. £180 posted
S15OC Heat shield £40 posted
(I've cut a strip off the lowest edge that was interfering with the wastegate actuator IIRC. Two holes drilled into it are for wire locking to fasten it and stop it vibrating, and the bolt on the top will bolt into your ABS pump) Obviously used so a bit warmed up lets say.
Exedy Hyper Single Clutch/Fly kit, still on the car now, £270 posted
Also, if anyone wants a Garage D 'strengthened' 6 speed box that failed me let me know. It only had 15k miles before it failed. 5th and reverse still work, but it just lost drive without a noise. £120 collected.
All parts located in Cornwall
Payment via bank transfer preferred, otherwise you pick up the paypal charges.
Max
24 January 2013
Kent
so whats the plan now max? are you going wide body on a re-shell?
Max
31 October 2010
Cornwall
Thats the plan! I'll be more realistoc this time and say it will take a few years if getting everything together before everything gets swapped
Max
31 October 2010
Cornwall
Slight change of plan, i'm going to keep hold of the heat shield as i still think i will be able to use it. Sorry!
23 September 2014
Maryland
If you change your might let us know. I've been looking for one for awhile.
Max
31 October 2010
Cornwall
I think I'll want a heat shield even more with a top mount :s
Max
31 October 2010
Cornwall
It is prov. Sold at the moment. Lots of interest. If anyone wanted to collect though they'd probably jump to the front of the que, dont want it getting damaged in the post
