L
Luddy-C
Been searching around the net and various forums but I've given up and figured I'd just ask
I've got CS2 coilovers and rear camber arms on the S15. There's other bits too but I just wanna ask about camber and damper.. The car had all this already when I bought it so I havn't adjusted anything...yet :wack:
Basically, the CS2's have adjustable damper via a twistable knob on the top of the rears and the bottom of the fronts (please correct me if I'm wrong
). I was curious about messing with them but I wanted to know if I need to jack the car up or even remove the shock to do it? Or if they should be adjustable on the ground?
The other question is the rear camber. Do I just remove the wheels and the camber arms and make them both shorter/longer and ensure they're the same length? Or do I need to adjust the top mounts of the CS2s aswell? Or adjust anything else?
Sorry if this has been asked before, but I couldn't find it. Thanks for reading! :thumbs:
