Advise please what to use ?
black country
www.coordsport.com
ok my fmic is on :D
i'm yet to take it a test run as i have to get my bumper back on,
So what do you guys recommend i use to cut the bumper ?
i have my dremel waiting and i plan on a trip to B & Q to get a diamond cutter for it,
is this the best thing to cut it with? or do you guys that have already done it know better ?
Any cutting help will be greatly received :thumbs:
kimi xx
sushiming
13 November 2005
Hong Kong
not sure hehe i had mine done for me heheh...u didnt comment on my fmic :p
sushiming
13 November 2005
Hong Kong
have u check what i upgraded heheh iam well past u now heheh wll for now anyway
I just used a Dremmell disc attachment. I'd suggest putting the bumper on as much as you can to mark up the bumper where it needs trimming. Apart from the obvious bit around the pipes, the rear of the scoop will need trimming. Its a gradual process. Don't take too much off at once.
L
Lee75
I did mine at work so i had the use of many power tools :D but i ended up using a big belt sander on the bumper :D
the bumper was on and off about 5-6 times till i got it right :nod:
K
kieran
pmsl, i seem to have took the hard route i gradually shaved enough off with a steady hand and a stanly knife! :eek:
OMG. that must have taken alot of time.
About the same as cutting the steel on the chassis legs and front bumper support with a dremel, which I did :eek:
I used a dremel to cut the front bumper. Then used on off those round sandpaper bits on the dremel to get it nice in the end.
Derek
Baby Angle Grinder for me :D
Kimi keep an eye on boost carefully after fitting fmic. Mine went gaga after fitting front mount
black country
www.coordsport.com
cheers guys its on :D
its fitted on nice and i had a hks evc5 fitted at the same time,
so my boost should be ok.
i'll put some pics up on another thread.
kimi x
