V
VS15
Hi guys ,
Wish there is a track section for discussion . Am having some headaches related to my car behavior as am setting it up for time attack , the tail is too wiggly powering out from a corner and it doesn't feel stable on high speed transitions.
Below is the car setup and hope to get the veteran trackies recommendation on what's a better setting to go for
Front:
Camber : -3.5 degrees
Toe: 0
Caster: 7 degrees
Rear
Camber: -3degrees
Toe: 0
Suspension:
custom valve rebound rate
Front spring rate : 13k
Rear spring rate: 12k
Wheel size: 255/40/R18 front and 255/40/R18 rear with Federal Semi slicks
Running a 2" front splitter with a 1500mm rear wing bolted to the trunk.
Car is currently putting down 490hp and 450Nm Tq
Any advise to make the car more stable powering out from mid corner to corner exit will be appreciated. I know it depends on much more variables on car setup but hope to get a general idea how am i doing thanks.
Front:
Toe: 0
Caster: 7 degrees
Rear
Camber: -3degrees
Toe: 0
Suspension:
