Boost issues
2 September 2012
Norwich
Was out today and noticed I'm hitting 1.73 bar if boost. It's shpuld only be hitting 1.3 bar in low.
Can't see any pipes hanging off anywhere, no smoke either.
Any suggestions?
got another boost gauge to you could fit just to see if your current one is faulty, put a small and slow amount of compressed air into the actuator so see if the arm is moving, or if you have a external do the same thing to to see if the valve is moving
2 September 2012
Norwich
It's reading 1.53 on PFC and boost gauge. Hitting 1.73 on the AVCR! Will have to run it to APT soon.
Other than that its running fine at lower revs.
2 September 2012
Norwich
Sorted. Actuator pipe had split.
Fixed within 5 mins
