Cabin water leak
Max
31 October 2010
Cornwall
Odd problem here.
It has been bloody wet recently and since December I have been getting into the car and feeling that the drivers carpet around the pedals is wet. Thought it was wet feet initially but has been getting wetter in wet weather. Blasting hot air does shift most of it on a long journey only to return.
This is happening only when stationary and is starting to peev me off. Anyone heard of a leaking point around the drivers footwell, pedal area?
I did fit my lambda sensor back at the end of last year and the cable does route through the drivers footwell loom grommet, but lots of other things go through there too. Maybe I have poked one too many holes in it. If so repair ideas?
Max
17 January 2012
Essex
@kwalker88
Grommit in the drivers arch. fill it with some sort of sealant and dry it with a hair dryer if you can. Try and avoid driving it until its dry as it can blow out, i realised that after i got home :)
24 January 2013
Kent
silicon would probably do the trick just dont get it everywhere
Mine was the gromit! Too many holes with things goin to the cabin. Dry it out and seal the gromit with silicone sealant.
