Change side indicators?
daniel83
Hi everyone!
I have a question.
How do you change the side indicators?
What do you need too remove and soo on?
//Daniel
SherlockHomeboy
Just pull it out
all you need is a bit of muscle
daniel83
Alright.
Thank you!
mint
18 March 2007
Asakusa, Tokyo
www.JDMtas.com
Yeah its not a hard job, but when you do the first one you will see there is a certain way they pop back in. Easy job mate
When I did mine, I thought I was going to break them. It does take a bit of effort to get them out.
19 June 2007
Essex / UK
Just be careful not to scratch the paint, if you use a flat head screwdriver wrap the end in a tea towel or something else soft.
^^^ What he said
20 May 2008
Hull, UK
raduga-uk.110mb.com
Screwdriver??? Not near my paintwork!! :D
One end of the side indicator will compress when pushed, then you can pull the other end out. Try pushing them towards the front or back of the car. You'll only see them moving in one of the directions.
It takes a bit of force but can be done without any tools. The main problem is they tend to be weathered in. You just have to break the 'seal' holding them there.
Russ
david
Just push the light twords the rear off the car it will feel springy then pull the front part out.
