- 13 November 2005
- Hong Kong
- www.s15oc.com
I need to replace them so i thought i would be nice and sort out a brake pad changing write up at the same time for the people that havent done it before
so here we go......
Tools you will need
Jack, Screwdriver flat bed one, clamp, copper grease,
First un do the wheel nuts before jacking up the car otherwise u wont be able to gett he wheel nuts loose
The PADS
Find the jacking point under the the side skirts please becareful in jacking the right point as u could end up cracking ur side skirt if u jack the wrong point
Then nuts and wheels off....
Then at the back of the caliper there is a pin which holds the other two pins which u can see on the outside, carefully pull the pin at the back out of the other two pins
once the pins are out u will need to use the clamp to clamp back the pistons using the old pads
OLD AND NEW PADS
so here we go......
Tools you will need
The PADS
OLD AND NEW PADS
