FS: Cheap SR20DET (VVT)
immy21
9 November 2012
Edinburgh
I have an engine that came out a 96k auto s14a that spent most it's life standard, then went 1a (manual conversion) and the head gasket failed. Rather than changing the head gasket I swapped engines with a spare I had and planned to forge this one. That cars gone now so this engine is for sale.
It is a stock unopened engine, as far as I am aware.
The engine did start and run although obviously rough, compression test results are below and did not raise with oil so I think it's safe to say it's head gasket.
Small MX5 battery and a cold engine
1:
2:
3:
4:
I will sell you everything in the below engine pics for £250, so this included alternator and a power steering pump not pictured.
No injectors.
UK Mainland pallet delivery approx £65
Now finally some rules, I would rather stick it back in storage and keep it as a spare than have to deal with a headache so...
I will not accept refunds, if you tear down the engine and find big ends gone or piston damage just as an example, it's not my problem.
IF requested, I am willing to remove the head and/or rod caps (crank too If I can undo the pully) only after you have paid and if anything unexpected is found I will refund you, it may take some time for me to do this though.
immy21
9 November 2012
Edinburgh
Other spares I have:
SR Gearbox £150 (Manual conversion available)
Full new unused genuine Nissan Gasket kit £100
Horsham Developments Stainless manifold SOLD
Coilpacks with loom £50
I won't sell the gasket kit or coil packs until the engine is sold.
Cheers
Immy
immy21
9 November 2012
Edinburgh
If the engine doesn't sell soon I'l be opening it up for inspection.
21 July 2011
England
How much for the manifold and gasket kit posted dude?
immy21
9 November 2012
Edinburgh
Gasket kit isn't for sale unless the engine sells and the kit is spoken for if the engine sells without it
I'l do the manifold for £60 delivered due to a tiny crack that could do with a little weld. This is super cheap to get it out my way.
21 July 2011
England
Is there any more cracks? If not I'll have it I'll sort payment out tonight dude
immy21
9 November 2012
Edinburgh
Nope, even this ones some minor I never noticed it until a couple days ago, I'v had this mani since new. I'l pm you payment info.
21 July 2011
England
Money sent for manifold
immy21
9 November 2012
Edinburgh
Everything sold apart from the engine.
Last and final bump for the engine otherwise I'm going to strip the engine down, then sell it off in bits. I'l start a new thread once stripped.
