Cusco VS Nismo Sway/Stabilizer Bars
SR2O
31 August 2006
Melbourne, Victoria
Hey Guys,
Interested in people's oppinions on Nismo vs Cusco sway bars, which do you think is the better item and why? Thanks in advance!
Tomi
No idea. But I've got Whiteline and find them fine. :)
13 November 2006
Swindon, UK
How much of a diff from stock?
Also, could someone mesure the dia of the stock ones versus Nismo/Cusco/Whiteline?
Cheers.
I'm not in a position to compare. However, I fitted ARBs/swaybars before coilovers and it was a BIG difference to body roll.
I believe Cusco has the same diameter as stock swaybars but with harder compound. Some say it's not worth it cause it's the same diameter.
If memory serves me right, front nismos diameter is same but rear is alittle larger.
S1Five
can anyone confirm the above?
S15R
nismo bars are the harderest you can get
i ahve cusco ones and they are bit bigger than stock the front is thinker and stonger and the rear is a thinker and stonger
compare to stock they are a lot better as stock ones are hollow eg dont have anything inside them but the cusco ones are solded
i would say whitelines or cusco will be good enough and depending on price really if u can get nismo for about the same price as the others why not but at the time when i got mine cusco ones worked out cheaper than the whiteline ones so i wne t for them ones
Glad you can clear up some confusion. Thinking of getting cusco ARBs as well since I like blue colour. lol
S1Five
anyone have any good sites with specs on the sway bars available for s15?
so maybe a comparison between them or just the different sizes
are they/any of them adjustable?
No idea.
The Whiteline bars have three different settings :)
E
evade
the stock ones are hollow tube..so any solid bars..even if its the same size..will be a big improvement..i.e. cusco ones which are the same diameter..but solid bars..will make a difference
