Custom Map... Which one?
5 November 2008
Hertfordshire
Hi guys,
I am getting my car mapped in march but I still havent decided what one to go for. :confused:
Here are the 2 options I have boiled it down to:
1) Jez at Horsham Developments custom map �375 + �80 for Dyno Time
2) Steve at FC Tuning using Nistune software �420 + �75 for Dyno Time
I have read lots of threads on sxoc and here about the each of them and they both have good reputations and im sure will both do a great job!
I know Steve is more expensive but he is using Nistune and is alot closer. If I went with Jez and Nistune it would be over �500.
I will also be needing another map in the future when I have changed the turbo etc. and Steves 2nd remap is cheaper...
There are so many advantages for both I cant decide :confused:
What do you guys think?
If you have a second re-map by Jez it is only £150 IIRC, unless you change the injectors or AFM
Edit: If you want to save money get Jez to do it on the road. Everyone has different opinions about this, but when I got mine done I spoke to Jez a lot about this and he said it makes no difference where its done. You drive your car on the road, not a dyno, so the conditions with on the road mapping are more consistant.
5 November 2008
Hertfordshire
Yh ive been thinking about this alot, when I was at uni I mapped on a dyno and ALL race teams do the same, with a bit of tweaking on the track when they get there!
Im pretty sure ill be getting it done on the dyno so now just got to decide whether I want Nistune or not.
Also the only reason I will be getting a 2nd map is because I will have changed the AFM and injectors etc.! lol
I haven't heard much about Nistune, but I was going to take the trip down to Jez to get mine remapped, which is a 4hr drive one way! I've heard many great things about him.
I've recently found a good place near me now, so I won't be going down, but I would of done had I not found this other place.
5 July 2006
London
Jez road mapped my car and he did like 10 runs up and down a road, then job done. :S Caused me loads of grief later on trying to find the source of the over fuelling! Turned out to be the map... (after I'd spent about £700 on replacement coilpacks, upgraded to splitfires, new plugs etc).
The only proper way of getting some steady state tuning is on a dyno. Obviously some tweaking on the road can be done after though.
I'd go for the Nistune and FC Tuning option without a doubt. Steve got over 40ftlbs more torque, and MASSIVELY improved my petrol consumption!
The amount you'll save in petrol will probably cancel out the price differences anyway! :wack:
5 November 2008
Hertfordshire
Cheers guys,
Ryan do you know if the Nistune Steve uses is actual Nistune software? Can you buy the plug etc and tweak it yourself?
I only ask because Steve calls it FCTUNINGNistune solutions...
Why not wait until then? would save you a few hundred quid which could buy your AFM and filter. :)
5 November 2008
Hertfordshire
Because I would only save £150, and an AFM on its own isnt very benificial... I really cant afford the injectors and turbo to compliment it!! :wack: lol
5 July 2006
London
I'm not sure, to be honest. I was running a power fc!
I believe it's a normal nistune though.
Obviously I'm a bit biased due to my previous experiences and I know alot of people do recommend H-Dev, so you should get a good result from him, but I can guarantee a good result from Steve! :D
You never know, you might e happy with it sitting around 300bhp after the first map. :)
