DB-Power Rear Caliper mod (big brake kit)
25 February 2006
East UK
Hi all,
Had a search but couldn't find any pictures or instructions ref the rear caliper filing/grinding mod thats needed for the DB brake kit.... Fitted mine ages ago and works a treat - car had the MOT and one of the calipers was leaking so the garage changed it and are nervous about how much material to remove... not enough was the answer as it appears to be stuck!!
Help with pics would be excellent!!
Why didn't they use the original as a guide for the new one?
Contact dan I'm sure he will be able to help.
25 February 2006
East UK
Dans on paternity :)!
Anyhoo I went down and guided them - its easy/self explanatory when you see it.... Phew! brakes operational for Track day at the MSVBedfordAutodrome on Saturday
Yeah I forgot that was today! Saw him Monday too ha ha glad it's all sorted bud
25 February 2006
East UK
Cheers :)
Track day was spot on. She went really well; spoiled quite a few much newer high spec cars ;-D
brakes held throughout; really good upgrade! and the first time I've tracked her with the new diff - brilliant!!
- next mod is insulation of the ABS and pipework so I don't have to pop the bonnet between runs to keep the heat soak down
