diff oil
5 January 2007
Ballymena N.I.
what oil shoul i put in my std s15 diff
sushiming
13 November 2005
Hong Kong
redline shock proof heavy stuff cant remember the proper name but thats what i use:thumbs:
and shock proof lgith for ur gear box
ichi-go
7 January 2007
Perth, Wait Awhile
I use motul gear300 for my gearbox. Cant be happier with what the car originally came with. Now going to try gear300 on my lsd.
I've got motul Gear300 in my box too :)
I'll put in some Motul 90PA in the diff soon.
Paul-S15R
Guys how much oil is needed for the diff and tranny? What viscousity do you use?
T
TonyS15
I have just ordered mine now. Nicely recommended Redline Lightweight Shockproof Gearoil in the Gearbox, i ordered 3 Quarts which is just less than 3 litres 998ml per quart i think.
Also ordered 2 quart of Redline heavyweight shockproof gearoil for the diff.
Think viscosity is something like 75w-90???
T
TonyS15
Sorry dont mean to hijack the thread but whilst on the subject of oil, i was wanting to put a filtermag on the filter.....but trying to find the sizes. Does anyone know the size of the filter?
Is it a) 63-70mm
b) 70-87mm
or
c) 87-99mm
Phone a friend, Ask the audience or 50:50...........:D
Also does anyone use a mag on the gearbox plug?
http://www.blue-diamond.co.uk/shop/index.html?target=dept_1.html
Helical Diff
1.2-1.4 litres
Viscous Diff
1.7-1.8 litres
The workshop manual recommends Helical diff oil be changed every 40000 km/24 miles or every 24 months. I says the Viscous oil just needs inspecting regularly, but I'd recommend the same as the Helical.
6MT gearbox
1.8 litres (overfilling to 2 litres from the top will give a smoother gear change)
5MT gearbox
2.4 litres
4AT gearbox
7.9 litres
The manual also says to inspect and change if necessary for the gearbox. I'd say change at the same time as the diff :)
Just get a Nissan filter :) Its fairly cheap and good.
The drain plug key is 13mm
T
TonyS15
Do you know the size of the filter???:confused:
Nope. I just buy the Nissan one, take it out of the box and fit it. :)
L
lj~R
Helical Diff
1.2-1.4 litres
Viscous Diff
1.7-1.8 litres
6MT gearbox
5MT gearbox
2.4 litres
4AT gearbox
7.9 litres
To Nicely
About the "6MT gearbox
just wondeing how do you overfilling your gearbox? I want to make more smoother...
thanks
Fill from the gear shift cover (which is easier and quicker anyway). You will need a 12mm flexi-necked ratchet spanner to undo the bolts :) I'd also recommend extending the gearbox breather slightly by sticking on a hose from the breather end and hooking it over the brake lines on the firewall :)
S1Five
can i just confirm the Motul 300 is perfectly fine to put into the diff of a helical lsd?
motul 300 = the gearbox oil im currently using
The diff oil should really be slightly thicker than the gearbox.
sushiming
13 November 2005
Hong Kong
yes nicely is always the man u need to find answers from :nod:
True. But that's the case with most aftermarket things :) For the 90% who don't run an aftermarket diff, its true ;)
and specifics weren't given! lol statement weren't given saying "i use this in my...." lol :)
are both the gearbox and diff a 13mm key? so basically, a 1/2" wrench?
