differences on S15 subframe
12 October 2009
California
is there a difference at all between S15 turbo rear subframe and S15 non turbo rear subframe?
im guessing theres no difference, but thats just a guess.
i need to know, im planning on using it on my S13 and i found a non turbo one.
22 July 2010
The subframe is the same yes, however there is just less bracing I.e anti roll bars are smaller etc etc. I want to know if the bare subframe on an S15 is the same of that on an S14????
12 October 2009
California
less bracing and anti roll bars are smaller on S15 n/a subframe?
S14 and S15 subframe is interchangeable, but S15 has more reinforcement.
if S15 n/a subframe and S15 turbo n/a subframe is not the same, i guess i will just go with an S14 subframe and just do some welding to make it stronger.
If you are going to use the S15 subframe on your S13 you will have to do a bit of cutting and bashing of the floor pan to bolt it up to the S13 rear
12 October 2009
California
yea im aware of that. i will be cutting some on the subframe
