Do 350z brembos fit s15
16 February 2009
antrim
I just bought a full set of brembos from a 350z, does anyone no if these fit straight on? And if so what size of discs and what do I ask for, 350?s15?etc, and do the rear calipers fit on or is it too much hassle, any info would be appreciated, thanks.
Baulkham Hills, Sydney
Fronts = YES, you will need to buy the 350Z rotor (324mm)
Rears = Not without big modifications (ie cutting/welding etc)
japmadlad
28 June 2007
Armagh, N.Ireland
rear modification isn't that big. just need to get a machine shop to fill the holes for the bolts in the calipers & redrill them cause they are the wrong distance apart. However you must also remember that the rear on the 350Z is a disc & drum setup so you need to do the Z32/S13 rear handbrake assembly conversion or your handbrake won't work.
Everything you need to do is in the useful threads sticky at the top of the page.
I have the 350Z setup. it is awesome, well worth it & looks :cool:
