FMIC + boost drop
13 January 2010
Cork, Ireland
Just got a fmic and now the boost has dropped to .4 bar. I was expecting a drop but it seems a lot to me.
Do I have a boost leak or is that drop normal??
5 July 2006
London
That seems a bit excessive.
Does it idle ok? It sounds like a boost leak to me.
Have you got any form of boost controller on it?
13 January 2010
Cork, Ireland
Idles ok and no boost controller
Darren_S15
Club Event Orgainser
18 January 2008
Essex, UK
What was the boost before?
When I fitted my FMIC the coupling hose at the bottom of the cold pipe was comming off the hose, got so bad I eventually had no boost.
Check everything you have changed, must be a leak somewhere.
5 March 2009
qld,australia
Have you got the hose that runs from the factory boost solenoid to the intake side plumbed in right. If you do check that you have the restrictor from the stock hose and ram it down the new silicon hose. It wont boost properly with out that in with the factory controller. Also check you BOV isn't leaking(opening).
13 January 2010
Cork, Ireland
Checked the pipes and they seem to be fine and other ideas
The only other thing I can think off is the FMIC is possibly damaged and leaking itself?
Best thing to do is get soapy bubbles and put it everywhere you can think of to see if there's an air leak...
14 September 2007
Essex
@4ndy_hunt
sounds alot like mine. Are you over fueling at all?
13 January 2010
Cork, Ireland
Ya over fueling but was like that before I fitted the intercooler.
Had a good look again today and I found a small leak, fixed it but only got about .05 extra.
I'm thinking now that it's just the size of the intercooler.
Thinking of getting a boost controller to get the boost back up.
The size of the intercooler shouldnt make the boost drop, especially to that extent. You normally just get slightly more lag.
Check for split vacuum hoses too, that's a common one too and very likely as you're running on actuator pressure.
^^^ +1 deffo won't be size of intercooler. Lag is usually not noticeable until you start making very high bhp :)
13 January 2010
Cork, Ireland
:mad: another day, another failure :annoyed:
I can't figure out what is wrong
Have you deffo made sure the FMIC is not leaking itself or has damaged sides/core/fins??
13 January 2010
Cork, Ireland
i checked it but as far as i could tell it was ok
i think i will take it off again tomorrow just incase i missed anything
13 January 2010
Cork, Ireland
Ok checked the FMIC again and i couldn't find any leaks in it.
Is it holding and maintaing a steady 0.4 bar? If it is then it's more than likely going to be a vacum hose, rather than a boost leak.
jap spec s15? what were you running prior to fmic install?
13 January 2010
Cork, Ireland
Ya jap spec and the standard wmic
17 May 2010
Brunei Darussalam
I talked to my tuner about installing a FMIC and told me that im gonna drop to .4 bar of boost with my stock setup.
oh i mean what boost were you running prior to fmic install - 1 bar?
