Front lower inner bushes.
Fitted some front lower inner poly' bushes today. (Apex Performance)
S14 fit!
With these, you need to leave the standard sleves in, so no need to press anything out....
easiest way to sort these... drill out as much of the standard bush, between the inner sleeve and outer....
then..... in a cut down tin can.... petrol, and light it... burn the old bush. Try to pull out the old inner sleeve as soon as you can, the sooner you can get this out, the quicker it'll burn, cause the fire below will come up through it.
You'll need to use a screw driver to scrape out as much of the old bush to speed up the process. :)
New bushes will just slide in with a bit of lube.... we used tyre soap, because it's known to be save on rubber... silicone spray will work... or something that everyone has... washing up liquid. DO NOT use penetrating oil, it will eat into the new bush!
nope.... just done the front atm cause i knew i was takin' it all apart. :)
why'd you ask? :)
