Nemesis Guy
- 10 July 2008
- Age
- 39
- UK, Birmingham
- www.nemesisuk.com
Garage Clear Out 2: Part Shop Max Steering Rack Eccentric Bushing & Cobra Down Pipe
Having a garage clear out of all the parts I have built up over the years for my S15 Build. Now with a change of direction all my parts are available to you lucky guys!
All prices include UK Mainland Recorded Postage/Courier. Available to Ship International please contact me with full address to obtain prices. Collection available from Bromsgrove B61 0
Part Shop Max S14 / S15 Steering Rack Eccentric Bushing
Anodized gold solid CNC aluminium bushing set installs in minutes!
For cars with stock caster or less than stock caster
Helps to prevent over centring of tie rod and knuckle to prevent heavy steering at lock be moving rack a small amount, 4-5mm
Takes ackerman curve from digressive to progressive difference while decreasing overall ackerman
Improves steering feel by eliminating the rubber OEM bushings that let the rack move around too much.
Use Loctite on all 4 mounting bolts and mating surfaces of the solid bushing and tubular rack.
Don't over tighten past the bending point of the top bracket or the tube side of the rack will crush and rack will need replaced.
Not to be combined with Parts Max S14 rack to inner tie rod 36mm offset spacer unless you grind the FLCA mounting nut/bolt in half.
£50 Inc UK Postage
New Parts Shop Max ‘Awesome’ Cobra Down Pipe. Possibly the best Downpipe on the market.
This video explains it all.
https://www.youtube.com/watch?v=fLwbMqDeMpY#t=132
£230 Inc UK Postage. Sold
£50 Inc UK Postage
