harness fitting
mattyb
28 October 2011
gateshead
any body got harnesses fitted in there 15 without a roll cage where did you fit your rear aye bolts to.
im going to be using weld in i bolt plates but im unsure where to fit them
drifter
4 April 2011
Norfolk
I've got them in mine :) The rear eyelets use the rear seatbelt mounts, one of the fronts also goes in the seatbelt mount and the last one fixes to the trans tunnel with a FIA plate :)
The rears should be higher really, but without a cage you stock tbh. I did look for a harness bar, but couldn't find one for the S15. Mazworx do one for the S13/14, but when I measured the width of the car they were not the same :(
mattyb
28 October 2011
gateshead
I was thinking about welding fia plates on too the parcel shelf or welding a piece if cds tube in between the rear shock towers to wrap the harneses around but im unsure if the straps will be long enough
drifter
4 April 2011
Norfolk
I wouldn't rely on the parcel shelf, it's not that strong. Welding a decent bit of tube between the towers would be a better option, I think my Luke harnesses would just about reach but it would be very close.
If I knew it could be made to fit I'd buy one of these...
http://www.mazworx.com/product/safety/harness-bars/harness-bar-schassis
mattyb
28 October 2011
gateshead
funky power do a 49" NRG harness bar that is supposed to fit an s15. but there website is crap and there communications are even worse, so i haven't heard back from my email if they have them in stock or not.
drifter
4 April 2011
Norfolk
I did see that, saw that it said it was made from ally which sounds a bit pants imo :)
Is your car in bits atm? If you can get a measurement between the pillars where the seatbelts bolt on I can get it double checked to an S14 :)
mattyb
28 October 2011
gateshead
i will have a measure tomorrow as im doing some work on the car over the next few days. so ill let you know. thanks dude
drifter
4 April 2011
Norfolk
Good man, I know someone with a S14 in bits as well so I can get that measured :)
