Help on wheels offest asap for clearance
12 August 2013
Horsham, West Sussex
@liamb91
Hi all
need help, ive just bought some new wheels the fronts are 18x9 ET30 will this clear my coilovers (apexi N1's)? If not what size spacer will i need!
anyone running a similar setup?
^ sounds about right. Also will depend a lot on what tyre size you run and what camber you are running .
I run 18x9 et20 on the front of mine , fits perfect on a 225/40 tyre so that would be the same offset if you were to run the 10 mm spacer
16 August 2013
W.Mids
put a 9j et25 on the front of mine to try the other day, tight to the coilover (HSD CS1), less than 5mm clearance an et30 wouldn't fit. Of course, with different wheels and coilovers you might have different results.
26 November 2014
UK
Mine are 9.5 ET26 and fit fine with 225/40/18 and no spacer. HSD coilovers.
Must be close Mitch??
So common consensus is 9j needs et25-20. On standars arches! With a slight stretched 225 40!
26 November 2014
UK
They seem to be okay but I won't be driving the car for four weeks as I'm going overseas so will tweak it if necessary.
