T
tripleJs15
Can anyone tell be why the s14 clutch won't work on the s15 gearbox ? I've searched but found no definite answer.
Any help would be great, thanks.
No you don't. I have the standard S15 dual mass fly with a S14 clutch kit in my 6-speed box and it works perfectly. There are no physical differences between the 14 and 15 clutch apart from the 14 ones have springs in the friction plate to absorb harsh loads. S15's don't 'need' this as the dual mass fly does the same job but fitting a S14 clutch to a S15 will not be detrimental at all.The dual mass fly wheel is the stumbling block on fitting an S14 clutch. You need to fit a single mass S15 fly wheel to fit the clutch.
This is exactly what I'm trying to answer, did you or someone you know already do it ?You can do a z32 gearbox conversion with the 6speed clutch/flywheel now![]()
