Already have this posted up on the SXOC but I got very mixed responses so thought I'd post up here to see if anyone can shed any light.
This has really started to do my head in now.
My steering vibrates very badly between 70 - 85. It's almost unbearable and when I turn slightly at those speeds, it gets even worse. High speed cornering is the same when taken above 70. It's driving me nuts!
I had my front wheels balanced just 2 weeks ago for TOTB but didn't make any difference at all.
It all started after I had my Evo 9 big brakes fitted with caliper brackets made by DB Power. The kit wasn't a straight fit and the caliper had to be skimmed where the holes are for the bolts. It all works well apart from the immense steering judder.
Before this, I had stock brakes which also used to judder between 70 - 80 but not this bad.
I got new track rod ends fitted a month ago as my old ones had lots of play but this hasn't made much difference either.
When my local mechanic jacked the car up and checked for side to side play, there was none at all. He also checked the arms and they were fine along with the bushes.
The car feels unstable at high speed cornering and feels like the front could break loose any second. The rear feels planted.
Any ideas
Any ideas
