lambda sensors/rough idle
28 August 2006
sheffield,south yorkshire
are the universal ones any good? getting rough idle and overfueling once warm and when you unplug the lambda it starts running better. Anyone any ideas
I had to replace mine last year, and used a universal Bosch one and it's been ok still! But would recommend using Nissan one if possible.
If you have access to a multimeter, check the voltage at the grey or black wire (can't remember which is heater wire), at idle it should switch very quickly between 0 volts and up to 1 volt.
drifter
4 April 2011
Norfolk
I bought a cheapo from Gendan, didn't last. Tried another and it was shot in 2 weeks...
Genuine Nissan one was fine never had a problem, but are more money. The Bosch one that Sam used should be a good middle ground :)
28 August 2006
changed it today with a 3 wire universal cheaper one and runs spot on, unsure how long it will last?. Are they ok non genuine it wont alter the fuelling causing damage should it? It runs and idles great now
drifter
4 April 2011
Norfolk
It'll run fine, mine just didn't last long, first was about 6 weeks. I thought that would be a one off so bought another which lasted about 2 weeks :( Both broke internally so you could hear them rattle when you shook them :) Went for a Nissan unit then and it was fine :)
28 August 2006
Thats what had happened to the original one was all rattling and broken inside.Ill try it see what happens. How much was the nissan one
drifter
4 April 2011
Norfolk
Over £100, a Bosch one might better if you do run into trouble :)
26 February 2010
england
Where can you find these to?mines abit rough once it's had a blast and warmed up after a hours drive ?
als_jordan
13 July 2007
Does anyone know the Nissan part number for this? My Gendan one has lasted approx. 2.5yrs but has now gone again?
Also what are the HDev ones?
als_jordan
13 July 2007
Should have checked the link first - dope! Thanks man, that is a good price!
wicked price,all fittted perfectly even had a new little plastic clip to hold the cable out the way love oem parts lol
