Paddy
okay... last night was out cruising around. i gave it full throttle in second gear, at spike boost / full boost or 3250ish rpm it developed a loud screaching like sound. its the type of sound i would associate with a slipping belt. it is also similar to the induction note of my hks suction filter... except much higher pitched. its recreatable too, full throttle in second gear and i hear the noise
boost-wise i'm running stable at 0.8 bar, but i have seen spikes up to 1.1bar!
the boost gauge is reading as it normally does. i cant see any pipes off, eg the actuator, boost sensor, relief valve. i'm swithing back to the factory solenoid to see if its in the relief valve.
i suspect that it maybe the fmic piping with a pin hole leak, exhaust leak or could it be on the fresh air side of the turbo?? i would be very interested to know if anyone has had similar experiences, and what you think i should be lookin out for. Thanks.
Paddy
BTW what does WOT stand for
Paddy
