Nistune on Spec S
27 October 2010
Killarney, Ireland
First off I haven't a clue about ECUs so i don't know if it even exists for Spec S. Did a bit of looking online and couldn't find out anything solid.
So firstly is there such a thing as Nistune for a spec s NA?
Is it worth doing? What power increases etc?
Whst kind of money would the set up be?
mattyb
28 October 2011
gateshead
I should imagine it would be about the same price to chuck a DET in
Sent from my iPad using Tapatalk HD
Have a word with someone like Greg at Protuner or jez at Horsham developments .
Rough price for a nistune fitted and mapped is £600
Jez does his own boards that are cheaper but only he can map. I would give one of them a shout ,I'm sure they will be able to tell you if they do an ecu for your car and what you could expect gain wise. All cars can be mapped ;)
Tbh i agree with the above though, det would be the easy route for more power if that is an option for you?
4 August 2011
I think that the price would out weigh the benefits tbh. If you have the know how it would be much more worthwhile to do an engine swap. It shouldn't cost a lot more but will give you vastly greater future potential..
they way ive always seen it....... for light Jap rwd cars
if you want a tuned NA rwd you may as well go buy a S2000 as thats NA perfection
otherwise for the same factory power output a Spec R is the way to go for boosted options
You will only be improving your AFR tune so the car runs at peak efficiency...NA life
Trial_S15
13 July 2008
Meath, Ireland
www.modifiedmotors.ie
There's on guy called Stiv on SXOC that does Nistunes in Ireland but IIRC I spoke to him about it when I had mine and as above there was no real benefit considering the cost of it, plus you would really want to also port and polish the head and get an aftermarket exhaust manifold to see any real performance gain and at that rate you'd have fitted and upgraded a SR20DET for less and got much more out of it!!
Plus if you did that now and chose to go down the DET route later it's wasted money & effort as the R ECU is different...
27 October 2010
Killarney, Ireland
Well that answers my question. Won't be going down that route haha! DET it is if i ever go looking for more power. Thanks for the responses.
