- 23 May 2012
- Edinburgh
- www.facebook.com
Hey all, problem solving time:
I'm getting a loud clunk noise when driving at any speed, turning, going over bumps or cambered roads. Its the front driver's side tension rod I believe. I have adjustable ones, not sure of brand
I took it out tonight and one of the two metal pieces circles here in red sticking out was looser than the other and came out from the rose joint very easily, is this supposed to happen?
Also, when moving things to try and get the sound out I managed to get the centre section (blue in the picture below) and the end nut to move quite easily with a spanner, and the rosejoint bushing moved with it.
I checked all bolts around the area, have new brakes, new coilovers and had many other people confirm the tension rod is making the noise. You can force it to make the noise by pushing the car down at the front and lifting it again.
Is this fixable or am I best to replace the front tension rods?
Thanks,
Chris
[/URL]
Thanks,
Chris
