eiden88
Hi boys n girls,
up for sale is my used but in good working condition os giken super single sd480 clutch kit
it's the pressed steel pressure plate edition which is rated at 480+ hp
Putting this up for sale as it's definitely an overkill for a daily driver with less than 280hp that never sees any track, so I went with a driftworks flywheel and exedy stage 1 clutch, instead of skimming this and getting a new clutch disk...
considering this is 800€ new +shipping+customs from japan I think that 300€ would be a reasonable price
this one http://www.rhdjapan.com/os-giken-super-single-pressed-steel-clutch-kit-nissan-51290
remember : this needs skimming (got a mechanic buddy check this out and he said 1/10 mm skimming is more than enough as it doesn't have any surface scars) and a new 225mm sprung (or not, if you hate your gearbox
) clutch disk
will be putting pics later as soon as I get back this night
pics
Very dirty I know, I'll give it a good clean asap
edit: forgot to say that this will come with brand new grade 10.9 or better grade pressure plate bolts, two used os giken clutch disks (have no use for these
) and a used release bearing with the thingy that holds it... both disks have some meat left on, but springs have some play, so I would get a new one (any 225 mm s14/a disk will do), unless you can use them anyway? flywheel bolts will be included too, but I recommend getting new ones, like ARPs, but any bolt kit for s14 will do as far as it's 10.9 or better grade :thumbs:
thanks for watching
pics
thanks for watching
