osgiken clutch seems slipped but not
Sair
28 December 2010
Northampton
i just change my s15 std clutch to os giken twin plate . the giken clutch is actually bit used and took out from driven s15 but i cleaned the minor rust on it except plates. now the issue is that my car is not gripping ( high rpm but no speed above then 50kmh) it seems like clutch is slipped but no smell because of almunium plates..
several advices have been given to me but not satisfied im much prefer to authentic and professionals
1. drive the car around 50 to 60 km it mite grip
2. take out the clutch and clean the bit rust on plate it and put it back again
3.take out the clutch set it. teeth (grind) by lathe machine guys
4. check it isn't push type or pull .. or it mite be adopter of push type with the plate..
have you adjusted the pedal position? if not it might be holding your clutch out slightly
Did it come with the flywheel and flywheel bolts?
and is it the S15 6 speed specific one?
Sair
28 December 2010
Northampton
yes it comes with the flywheel and bolts and it is out from a 6 speed s15 .. secondly is there any possiblity of pressure setting of used clutch...
As Spoonman said have you adjusted the pre load on the peddle, being a twin plate compaired to your old single plate.
