overfueling?
24 January 2013
Kent
i have a sneaky suspicion my car is over fueling or something else is a miss but how can i accurately tell?
I have a serious amount of black soot/**** on my rear bumper to the point that I'm having to polish it every 100 or so miles of driving. It was bad when I had the CAT but now its a lot worse.
car drives fine and has plenty of power, doesn't miss fire and only pops on up shifts when warm.
current mods: full 3" turbo back with decat, FMIC, EBC set to 0.7 bar, HKS air filter
I don't know this cars history in japan so something could have been changed map wise and then bits taken off before auction i don't know. Car has never failed an MOT so emissions have been sound. I think i have stock injectors but again haven't looked.
There is no smoke under acceleration (blue or white) and its not burning any oil. any help would be appreciated
1 May 2015
The Netherlands
got any pics of the soot after lets say 100 miles?
it's normal that it turns black, they run rich (what isn't a bad thing)
i recon you have a white S15? hite some how attracts filth
it sounds pretty normal to me, had it on all my turbo cars
easiest way to make sure is just buy a AEM wideband, is around 140 pounds on ebay and one of the best thing you can buy IMO
great for really knowing what your car does fuel wise and if it is safe/something is going wrong
24 January 2013
Kent
whats the difference between a wide band setup to a normal air/fuel ratio gauge? as a gauge is about £60 but the AEm wide band is £140 ish
1 May 2015
The Netherlands
A normal (narrow) band sensor is in every modern car and tells the car lean or rich, hi or low (bellow 14.7 and above 14.7)
The ecu uses this for stationary situation and cruising
This is good for emissions and fuel consumption
Once you ask the engine for power it discards any input from this sensor
A gauge as you describe is something complete useless IMO, let's you monitor this sensor
A wide band tells you exactly what you mixture does
So if you go wot and see a mixture of around 14 you know your fueling is off and you are better of checken it
If it goes to let say 10.5 you now you provably have a boost leak or something
Expensive standalone ecu's can be programed to use a wideband, normal ecu's don't cause that is to expensive :'(
24 January 2013
Kent
after 250 miles
1 May 2015
The Netherlands
That does look like a bit much
Maybe vault in fuel pressure/vacuum hose?
Best way IMO is to get a wideband and know
24 January 2013
Kent
Yeah will invest in one next month, could a boost or exhaust leak cause this? It spools to 0.7 by about 5500 which should be normal I think
1 May 2015
The Netherlands
Yeah if you got a boost leak the ecu thinks here is more air going in than there actually is, so it over fuels
But .7 at 5500?! Should be .7 at 3000rpm
So I think you got a huge boost leak
Like if a hose is cracked
https://youtu.be/atretf9u-Mc
24 January 2013
Kent
Oh really!? Must admit it's started since I put the frount mount on. Will have to check with a smoke thingy now :( joy
1 May 2015
The Netherlands
No smoke thing needed, just get 2 plugs and a tyre valve pressure the system to 1 bar, you will hear it
24 January 2013
Kent
Ah yeah seen that vid on mcm, will get a couple of bungs turned up at work. Just hope I've not damaged the turbo. Done about 750 miles since the overhaul
