paint question
Anyone that knows anything about spraying/painting?
I want to paint my stainless steel coil pack over, so dose anyone know what type of spray can would do the job?
Thanks
Adam,
Easiest although not the cheapest option would be to go to Halfrauds and get:
Scotchbrite
Wet 'n' dry (1200 grit)
Metal primer can
Car paint can for whichever colour you want (or use their custom paint making facility if you provide a specific paint code)
Clear lacquer
Cheers James will put that lot on my shopping list.
Normally if its bare metal you should really use an etch primer first before the normal primer
I get all my paint from autopaint st helens,their colour match is spot on and even with the next day delivery is normally cheaper than halfrauds....
No worries Adam :)
Chris - I also use Autopaint down this way... do some decent colour matches!! :thumbs:
24 November 2009
North Yorkshire
might be worth getting high temperaure paint as well. because i suspect your coilpack cover gets pretty damn hot if its metal! and you dont want your lovely new paint cracking/bubbling :)
