passenger side mirror
8 May 2006
Dublin , Ireland
Hi guys need the passenger side mirror part number.
Is it possible to replace the plastic part the get screwed to the door. as the mirror had been ripped of from the screw fittings.
if so i need a part number for that part then.
sadly, the whole mirror needs to be replaced...
96302-85F08
96302-86F08
both are your colour code, but not too sure on the difference between the 2... hopefully someone can confirm?
Paddy
ray,
Do you have the service manual? look up section BT-52 for the mirror.
have ya had a chance to remove the inner plastic trim and see whats broken, is it the studs or the nuts holding it on...
I thought your mirror looked fairly intact so i'd be hoping its just the nuts or something, if so, you might get away with just putting washers on where the nuts go to secure it.
8 May 2006
Dublin , Ireland
hi paddy havent got time to have a closer look. thing is the nuts where its fixed to the plastic.
thanks dazz0i
can someone confirm which code is the one i need. just incase i might need to order one.
im thinking about some tasty craft square mirrors
8 May 2006
Dublin , Ireland
mirror arent heated.
will be having look tomorrow see if its bad or fixable.
will be looking at you guys for second hand ones if not fixable.
Paddy
96302-85F08
96302-86F08
the top one is listed for a K spec
the bottom for a *K spec
seeing as the asterix doesnt have a definate description, i'm uncertain about it. 75% sure it would be the top one; 96302-85f08
maybe the bottom one is heated or auto folding???
hmmm... funny thought, spec S must not have any mirrors!? didn't see a Q listing
