B
		bbq_chickenwing
Could someone please help by providing a photos of the output shaft on S15 gearbox?
I am deciding on if it is feasible to modify the S15 gearbox to run a mechanical speedo drive.
From the service manual, the output shaft looks like it has grooves to hold a worm drive with circular/pin clips?
The housing seems to have a casting for a VSS (speed sensor) using mechanical drive?
Basically I suspect the gearbox has provisions to install a mechanical worm drive at those 2 particular points. A photo would confirm this Assuming this is the case the worm drive could be installed like this;
thank you, much apreciated~!
