- 13 July 2008
- Meath, Ireland
- www.modifiedmotors.ie
I''m considering poly bushing the subframe in my S15 but I am a complete noob when it comes to stuff like this and I want to be sure before I order and pay for anything.
I've browsed a couple of sites and this is how far I had come;
- Front lower arms / wishbones x 2 (3 each)
- Front castor arms x 2 (2 each)
- Rear camber, toe and traction control arms x 10 (camber = 2 each; castor = 2 each; traction control arms = 2 each )
- Rear lower arms x 4
And then I went on the Powerflex site and got this for the S14 (I've mailed them asking whether the S15 bushings are the same or not and I'm currently awaiting a reply).
Front Inner Track Control Arm Bush 2 per car - ref 1
Front Anti Roll Bar Mount 25mm 2 per car - ref 2
Front Antil Roll Bar Mount 27mm 2 per car - ref 2
Front Tie Bar Front Bush 2 per car - ref 3
Rear Link Bushes 10 per car - ref 4
Rear Toe Link Inner Bush 2 per car - ref 5
Rear Anti Roll Bar Bush 15mm 2 per car - ref 6
Rear Anti Roll Bar Bush 18mm 2 per car - ref 6
Rear Trailing Arm Bushes 4 per car - ref 7
Rear Anti Roll Bar Link Kit 2 per car - ref 8
Rear Beam Mounting Bushes 4 per car - ref 9
Rear Beam Bush Insert kit 4 per car - ref 9
I have HKS Hipermax Pro coilovers on the car - will that make any difference as to what I need?
Also, what brands should I stay away from? The powerflex are the ones I had initially wanted but are very expensive when compared to the Driftworks ones (for example). I know you get what you pay for but is there a happy medium when it comes to quality -v- cost?
All help is much appreciated :thumbs:
