Quick clutch question
6 March 2011
Ireland
Hi guys, I have an s14 gearbox in my s15, the clutch is starting to slip so I'm pricing up a new one, do I need an s14 clutch or an s15 clutch? Any help and clutch suggestions much appreciated, thanks....
6 March 2011
Ireland
Cool thanks, I'm looking at an exedy stage 2 paddle clutch, anyone know what their like? I want a fairly aggressive clutch with lots of bite, so it will take plenty of kicking :)
Yeah, the flywheels go with the gearboxes so get a kit that suits your gearbox. Paddle clutches are not ideal if you use the car daily. If you try to drive them normally they wear out in no time too
drifter
4 April 2011
Norfolk
Paddles can last a while, I got over 20k out of my Exedy paddle with daily driving. It only slipped at the end of it's life when I upped the power to 375ftlb :D
6 March 2011
Ireland
S14 gear boxes aren't that bulletproof. Aggressive clutch and clutch kicking will eventually kill it.
Ha yeah I forgot to say I'll be changing the box at the same time ha,
They're cheap anyway so I don't really mind changing them out for a good one, it's grinding and leaking oil so might as well change it when I have it split
6 March 2011
Ireland
Thanks man, good info,
The car is my daily driver but it's only 5 mins to and from work and most other driving is done looking out the side window so the limited life of the clutch doesn't really bother me :D
2 February 2010
ireland
wel i have the 6 speed s15 box on my s15,,,clutch system is nismo supper copper mix,,but the pressure plates keep going **** on these,,so does anyone know if an exeddy disc and pressure plate will go with nismo flywheel,,also this daily driver and dont really drift at al,,shock horror,,,,but if anyone could point me in right direction ill be really happy,,,thanks,,also does anyonw know where to get new front brake discs ????:yawn:
If you want to go for another lighter than stock setup apex now do an s15 lightened flywheel with an act organic Clutch for around 650-700. Other option is to get a s/hand flywheel and a regular clutch but it won't take power/abuse as well :)
