R33 Skyline front brake upgrade
I know that all kinds of brake upgrades have been discussed. I don't wish to get into what is better etc.
The reason for this thread is that I need to slightly modify my front calipers to fit my new wheels because I don't want to use spacers. The wheels just touch the caliper on the edge and I don't want to modify the original ones. I am looking at whether I should just get a replacement set of S15 calipers and modify them or upgrade to bigger R33 front brakes. I only wish to convert my front brakes.
My questions are.
1) Does the R33 GTST skyline front brakes fit without any modifications? I don't want to run adapter plates or anything like that.
2) What size disc do you use, the S15 ones or R33 ones or something else?
3) If the R33 discs are used, are they a straight on fit?
4) Will I need longer / shorter brake hoses?
5) Will this upset the front / rear bias of my brakes?
6) Is there anything else I should know about this conversion.
I was under the impression the R33 calipers are the same caliper as the S15 ones but made of cast aluminimum instead or iron and the mounting points on the R33 caliper make them sit further from the centre of the hub thus allowing a slightly larger disc and fixing my wheel hitting the caliper problem.
Matt_S
Where do they touch? Need pics really, cos when you say its touching, it could be read as touching on the front face (as you look at the wheel). WHich Im assumign it is.
I have R33/R32GTR rakes on mine.
From memory theyre slightly deeper, so if theyre touching the std calipers, it will only make the sitiuation worse. (I also have a pair of calipers off my S15 for sale too btw ;) )
Anyway....
1) YOu need to push back the dust shield edge (or trim them) as they foul the disk otherwise and the caliper fouls a bit too. The caliper bolts straight on to the hub tho.
2) The R33 one. THeyre 296mm not 280mm.
3) See point 1)
4) No, std ones will bolt on fine.
5) Maybe slightly. But not noticeably enough to worry about it.
6) Its really good :thumbs:
IF you say the caliper is hitting hitting the inside of the wheel where it mounts the hub, then yes that will cure the problem. Mae sure you measure the difference first tho. THey sit about 7mm further out from the centre. I had to try this for a guy who bought some wheels off me that were oversized on the hub mounting face.
Hope that all helps.
Thanks for the info. I will try to get some pics tomorrow so you can see what I mean. I am just trying to work out if the conversion is worth it or not, or wether I should just get some decent pads and slotted rotors.
7 January 2007
Perth, Wait Awhile
If they are hitting your wheels, then swapping to a r33 brake will make things worse
here are some pics.
First one is how much clearance I have with a 3mm spacer fitted. As I said. I would like to get rid of the spacer as I am not too keen on them.
This one you can see the shape of the wheel spoke. They move further away from the caliper as the get closer to the outer part of the rim.
This last one shows where the contact is without the spacer fitted (just below the second S in Nissan). Unfortunately the paint was scraped off during test fitting of the wheels :(
Matt_S
Best thing to do is find someone with an R33 GTSt and ask if you can trial fit one of your wheels on his car. :thumbs:
my mate had one and he sold it a little while ago. :(
Might have to see if I can find someone else.
Matt_S
Or an R32 GTR non V spec. That would do :)
K
kazamas15
Is it possible to fit R34 GT-T's front caliper to S15?
Matt_S
Yes, but afaik they run the bigger bolts too - same as the R34 GTR. Might be worth checkign before you go for it and remove your current brakes :wack:
sorry for digging up old threads,
im looking into R33 turbo brakes for the front as well since they bolt straight on thought they would be a good choice, does the BMC need to be changed if only the front calipers are being upgraded? ive read the how to change the rears to Z32 and then change the BMC but for now just the fronts and put new brake fluid in.
(I have 18" wheels so i dont think anything will rub)
Darren_S15
Club Event Orgainser
18 January 2008
Essex, UK
Ive just fitted some of these to my car today.
They just fit under my 18" wheels, but they do fit.
Not planning on changing the BMC unless I get issues, but you should be fine with the standard one from what Ive read.
_Wing_
24 August 2006
If your car is turbo s15, then r33 non-brembo brakes will fit under your stock 16" rims, and you don't need a BMC upgrade :)
