Rear Hub
3 March 2006
Manchester & London
Can anyone tell me for sure is the rear hub carrier on S15 same as S14?
Thanks in advance
3 March 2006
Manchester & London
This is confusing me..?? I think some call it the knuckle . That big heavy metal things behind the hub that hold the brakes and connected to various arms.
I hope I made myself clear.....
:cool:
:nod: Same
Part Number:43018-70T00-
Description:HOUSING-REAR AXLE,RH
Part Number:43019-70T00-
Description:HOUSING-REAR AXLE,LH
3 March 2006
Manchester & London
Thanks Nicely once again....
Could you also tell me why my fast parts program is not working, is working fo rthe EU version but not on the JP file.
Do you have the two CDs in separate directories and each with a separate location listing in NFSET?
3 March 2006
Manchester & London
Yes it was working before but all the sudden it keep coming up with an "Error = 5 Invalid Procedure call or argument" message
Dont worry if you dont know, just thought you might have these expereince before...
If the CD files are on your hard drive, you could try replacing them with a fresh copy. Could have got corrupted. If not, try reinstalling the FAST setup.
Did you install any programs in between it working and not?
3 March 2006
Manchester & London
Nicely, do you know if the bushes on it are expensive to replace?? Surely they cant be hard to get coz they are same as the S14
3 March 2006
Manchester & London
I meant all the bushes on the housing rear axle...thats attached to the arms
