rear traction problem
6 December 2007
Limassol, Cyprus
Hi guys. I have a problem with my Silvia. Car is around 400bhp.
I am experiencing rear traction problems. When i am off boost at around 3000rpm and go full throttle
and the car starts raising boost at 4000rpm where i am full boost 1.5bar the car looses rear tyre grip.
I have a Tein Flex suspension and have it rather soft at the back, i have cusco anti roll bars front and rear.
I am also using Yokohama A048 265/35 rear tyres.
Do you have any tips to make my rear end more stable. Rear camber is near zero.
Thank you.
1 May 2010
Wolverhampton
What sort of tyre pressures you running? Could try lowering the rears a tad and giving it a bit more neg camber?
6 December 2007
Limassol, Cyprus
2 bar or 1.9. i do not want to lower the tyre pressure a lot because it gets wobly at high speeds.
negative camber won't make the tyre have less contact with the road on a straight line?
6 December 2007
Limassol, Cyprus
Pretty old. And they were sitting on the car while it was build for the past 5-6 months.
1 May 2010
Wolverhampton
Nah I thought if it had a bit more neg camber at the rear there would be more tyre in contact with the road so in turn there would be more grip and less chance of the rear slipping?
400bhp, with I guess similar ft/lbs of torque, is a lot to put through 2 tyres so I would expect them to loose grip in the lower gears. I'm running Pirelli P Zero Rossos on mine and they will spin in 2nd when it comes on boost (1.25bar) and the tyres are only about month old. I'm running a fair bit of canber on mine though which wouldnt help the straight line traction.
6 December 2007
Limassol, Cyprus
i am not only talking about lower gears up to 4th gear i have the same problem. 5speed gbox btw.
Oh right! your 4th is about the same ratio as our 5th in a 6spd box! Hmm, maybe there is an issue then! My first call would be a new set of rear tyres or maybe an alignment check to make sure nothing is up.
I would be changing the tyres first.
6 December 2007
Limassol, Cyprus
i already took it for allignment. so the suspect must be the tyres then. i will try a new set and let you know.
Yes was also going to say tyres first :)
Do you notice a difference between cold and hot grip? Is it worse when the tyres are cold??
tooley
When only sideways will do!
10 October 2009
West Midlands / South Wales
Man up! its 400 bhp in a car that weights **** all its going to spin up! just learn how to control it :D
^^agreed. spinning the wheels in a high gear is cool :)
WTF?? Has this become a Honda chav forum lol?? :p
We're not all silly boys and their toys prancing around going sideways and repeating 'y0 bitch my skillz are epic' all the time haha :D
tooley
10 October 2009
hahaha
on a serious note, if you want the back end inline either change your suspension setup (toe in/out etc) or buy a traction control kit.
tooley
10 October 2009
Seriosuly lu have you been in an sbody with over 380 bhp? the rear ends are so light even 265 tyres cant keep it inline.
Cant wait to get mine close to 400 :D
Before I changed to new tyres on mine, I slide the car in almost every wide turns. Thats what a RWD is for. <Wide Smile>
Feast Japan
16 February 2007
YOKOHAMA, JAPAN
www.feastautoexport.co
There should be a date marker stamped on the side wall. Example below.
If your on a budget and want to stick it out with a good s tire, try out Federal 595 RS-R. They dont have the best treadwear and are a bit heavy compared to RE01R/RE11, Advan AD07/08, but for the value you cant go wrong.
VS. A048
tooley
10 October 2009
I was going to buy some fedral 95rsr's for the front but im going to try the hankook Z somhing or other semi slicks instead.
