motoren
Hiya all
Im new to this site and new to driving nissan, but only 3 weeks after i bought my nissan s14 my gearbox broke down.
I opened it and saw what went wrong, circlip failure at 4th gear, I started to search the net to see if other people have had the same problem and there were alot
I have read through many posts, many people talk about a "circlip mod", i havent been able to locate any picture or manuals of what the mod is all about. So choose the change to either rb25, z32 or z33 gearboxes.
If i havent already bought a 2nd hand s15 6mt gearbox, i problably would have gone the way of fitting another gearbox.
The problem with the circlip:
I dont think its the circlip that fails, because there is no presure on the circlip itself other than the outer ring that holds the two c-clips together and there is alittle room between the circlips and outer ring. I think its the outer ring that gets bigger and bigger because the c-clips can move in and out. Please prove me wrong
I took a picure of the shaft with the two c-clips and the outer ring so you can see the room between them and what i want to do to prevent it from failing.
Best Regards
Kent Sorensen
Denmark
Best Regards
Kent Sorensen
Denmark
