s15 diff advice asap
8 April 2012
northern ireland
hi i baught an s15 specs and failed mot for no abs, on inspection it seems that the two way diff fitted is a non abs diff also no speedo, was wondering if an s14 or 14a with abs would this sort me out? cheers
5 October 2009
I think skyline have speed/ABs sensor in diff casing aswell. might be worth swapping one over but you will need to check.skyline will be much easier to source
As above I use a skyline diff on mine think its an r33 diff, has all necessary sensors !
drifter
4 April 2011
Norfolk
S14 diff should work. I've got the diff from my S14 in the S15 now :) Skyline diffs normally have 5 x 1 bolt pattern for the half shafts which won't fit, you need 3 x 2 bolt pattern.
5 October 2009
The casing is the issue not the actual diff.
Yeah I have 14a 2 way with 14a output shafts on the 15
