Spec R Full Throttle Hesitancy/Stuttering
A
AdamB
No end of troubles with coilpacks, bought brand new set, [Shameless plug to Apex Performance] fitted them and all was well. Car has now developed a hesitation at about 3500rpm at full throttle.
Part throttles fine.?
To try and describe it better its an almost strangled/ clogging effect lift off and it clears, foot down again and same happens.
If the all to common boost leak it is far more severe than I`ve had before.
Its deffo not fuel cut, nowhere near as violent (dont ask how I know:eek:)
Found a slight split in Fuel pressure to inlet manifold hose, changed.
Cleaned MAF sensor.
Still the same.:cry:
Rear silencer box on exhaust is damaged but not blowing (had a whack on road debris), could a iffy/damaged baffle cause a similar problem?
Still running standard boost control solenoid, again, do these cause similar issues?
Can a turbo stall? Its that kind of effect. If so how does this happen?
Its a great car but is driving me nuts at the moment!:annoyed:
Many thanks
14 May 2011
northamptonshire
mhmm....
sounds like a ignition problem to me. checked your coilpack harness?
if it is fine at half throttle, but struggles at wide open throttle, have you checked your TPS at WOT? as it could be giving a voltage that the ECU does not understand.
Check with the engine off but the ignition ON, put a multimeter in the back of the TPS plug, from memory the center one is the signal feed, and put the earth on the battery earth terminal.
Idle Throttle valve: fully closed 0.15 - 0.85V
Throttle valve: fully opened 3.5 - 4.7V
.45V WOT is the common SR20DET standard that most people go by
