Speedo and Odo problem
29 June 2017
Vancouver
@vancouvers15
Speedo isn't working and odometer isn't accumulating. 5 speed box and using Power FC. Hand module also not registering speed. ABS light on, front ABS sensors removed. ABS Controller (passenger side of engine bay) is plugged in. ABS ecu next to PFC appears to be connected. Likely the VSS (Vehicle Speed Sensor)? Asking because that's a $250 non returnable part and as much as I like spending $ to make the car right, I hate wasting it.
I guess I'm asking, is it possible to have the ABS disabled but have the speedo and odo work? I'm aware that the ABS and speedo share a circuit somewhere in the system. I also noticed the right rear sensor was unclipped I've reconnected it but no dice. Maybe the terminals in the connectors are corroded. I'll check again. Input or thoughts?
Pics of my car for attention
29 June 2017
Vancouver
@vancouvers15
Solved. Blown 15A fuse in an aftermarket set-up. Probably for an alarm that wasn't wired right.
Keifer1903
Instagram Staff
1 December 2015
So want that cage
29 June 2017
Vancouver
@vancouvers15
Thanks! I got luck. It was there when I bought the car. Had it out for a drive yesterday and heading to its first meet tonight!
