Hi Guys.
have some issues with the car yesturday..
Basically was parked waiting for GF, engine off but radio still on.
10mins later went to turn the car back on, got nothing as if the battery went dead.. engine was not ever turning and no cranking noise.
got a jump of 2 different car and a booster pack and still nothing.
i did notice some clicking noises and seemed to come from the indicator relay...
to make things even stranger i tested the battery to have 12.5 volts so battery should be fine. with no key in the ignition the horn or alarm would not work properly only just get a small beep as if there was not enough juice to it.
turn the key to first position i sometimes get power but seems to be very low, secound postion i was getting no power or some but then it worked all the lights inside worked. only thing the would not work was windows (had to manually power the motor to shut the window :annoyed
and wipers too.
when then try to start the engine everything dies and radio resets no noise except for thr funy clicking from a relay.
What can the problem be?? is there a relay or something i should be chasing after?
