- 14 April 2007
- Shropshire, UK
- www.lupix.co.uk
Ok guys,
Thought it's time we started some proper discussion on engine rebuilds as mine has hit 100k miles and I'm in the process of sourcing a second high mileage SR20DET so can pull her apart and start work on rebuilding. I'm hoping to get this all done before my current block decides she doesn't want to play ball anymore so will take my time to make the right decisions and source the correct parts. There's obviously gonna be bits I'll have to send her off for like head skimming etc but want to do the majority myself (maybe I'll only end up ripping her apart and getting the rest done by experience pros but we'll see haha)
I've always held the belief that I want my car to remain fun and entertaining to drive at lower rpms (fast and twisty roads) so I'm still not looking for 'well above' 400 bhp. However, if I'm gonna rebuild I might as well use internals that can take more abuse/power/torque etc. I'm not gonna go overkill and pay for forged this that and the other but upgrading will be key.
So... I've recently been eyeing up the Mazworx stroker kits. Here's what I can copy and paste:
We are proud to introduce our line of stroker kits. Available in 91mm (turbo applications) 92mm (N/A applications). Our stroker kits will come with the following:
Mazworx 91 or 92mm stroker crank. 91mm crank 4340 billet, full counter-weight, teardrop oil chamfer. 92mm crank 4340 billet, full counter-weight, knife-edged, straight through oiling holes.
Custom CP Pistons. Available in any compression ratio desired. Comes with pistons, rings, locks, wrist pins.
Manley Rods - good for 600hp ( on average). Can be upgraded to bigger, badder rods.
ACL race bearings set ( main, rod , thrust washers). Option available with 19mm wide rod bearing machining, and 5 hole main bearings (GTi-R standard)
Motor displacement:
87mm bore x 91mm stroke - 2.16L
90mm bore x 91mm stroke - 2.32L (Please contact us for this application)
87mm bore x 92mm stroke - 2.19L
90mm bore x 92mm stroke - 2.34L (Please contact us for this application)
92mm bore x 92mm stroke - 2.45L (Please contact us for this application)
My first question is even though I'm not planning on bhp figures like 450 to 500+ would it still be worth me getting a stroker kit that displaces to 2.16 or 2.19 (assuming I'm sticking with 87mm sized pistons)? Will there be more torque at the lower end so even if I was to tune to around 400 bhp combined with .86 AR trim turbo will it be a worthwhile upgrade?
If I keep the pistons to 87mm - will I still need to bore out the original cylinders slightly as I get the impression stock piston sizes are 86.5mm?
I'm also wondering what cams would best suit - Tomei Poncams seem to be around 256 deg but I've also seen 260/260 IIRC... think 275/275 is too aggressive and the whole point is I don't want to have to rag the hell outta her to get all the performance like a true track machine :wack:
Start your debates and opinions!!
Cheers,
James
Motor displacement:
Cheers,
James
