I've had no issues with HKS EVC V, I'm running about 17psi through my 2871r and it holds boost great.Still haven't learnt how to use all crazy functions it has on offer.
Good to know...Thanks (BTW, I'm watching this build for sure!)
ok? the offsets are PERFECT for that kit!the offset seem ok for the kit.. i'll be looking forward to seeing some pics of the kit and wheels together
With the R34 GT-R rims, it really depends on your suspension. Stock suspension they clear fine. Aftermarket is another story - I'm running Cusco Zero 2E's and I needed to run a 3mm spacer on the fronts as it was rubbing the collar.how hard was it to fit the r34 gtr rim?
Thanks for quick replyWith the R34 GT-R rims, it really depends on your suspension. Stock suspension they clear fine. Aftermarket is another story - I'm running Cusco Zero 2E's and I needed to run a 3mm spacer on the fronts as it was rubbing the collar.
In terms of tyres I've got 235/40/R18 all round. Hope that helps!![]()
Ah apologies, I also had to rub the rear gaurds as it rubs slightly when there is decent suspension travel.Thanks for quick reply
alright..I have an aftermarket shock so it may requires me to do modification to the guard? I've been told that you need to roll the guards to be able to fit them?
Thanks
Oh
The Nismo cluster was ~ $500 (Australian) new a couple years back.nice looking good. If you don't mind me asking did you paid full price for the nismo cluster? I'm looking for a 2nd hand one but they are pretty rare..
also any tips on fitting the wind deflectors? I can't seem to get the plastic gaurd off to get at the screws.
cheers..
The Brembo's are from an R33 GT-R.lovley example!!!
Are they Stock Nissan brembos???
