Very noddy oil level question
9 May 2013
Cornwall
Question is; oil level is just on the L on the dipstick. How much oil do I need to put in to fill it up to the H mark? Don't want to overfill it is all!
17 January 2014
South Wales
Prob about half a litre just put a small amount in then dip it again ​
pour a bit in, wait a min let it drain to sump, pour a bit more, until you have the level you want, if the cars been running the wait a few min for the oil to drain back to sump before topping up........ then find out why you are loosing oil
The top part of the dip stick reads about 1 ltr of oil, it's so people are aware that the oil level has dropped an amount without being at a dangerous level. It wont make any difference if you put 200 to 300 mls of extra oil in. Mine usually has 4 ltrs in it. The motor only takes 3.7ltrs which is a pretty small amount compaired to other 4 cylinder engines
on a funny side point, a work mates wife was told to keep her engine oil level full and dont let it get low..............she just filled the engine up with oil until it was at the rocker cover filler cap..........
1 January 2012
Good bitch. She did exactly as she was told.
She just didn't do it right.
well lubrication was not a problem.... compression lock might have been
Probably thought it was liking filling the car with fuel...
