whining power steering
V
vti_coupw
hey peeps ive noticed the steering has gone a bit whinney, when im parking or if im after doing rings or that kind of hard work, do ye thing its the power steering pump?
if so is it an easy to do
thanks
dave
sx-si
7 June 2008
hampshire uk
when did you last change the oil?
if your drifting a car your most likely boiling the power steering fluid or youve lost alot
also if you change with the wrong fluid it whines
V
vti_coupw
havnt changed that fluid yet, ive noticed that it looks lik its boiling when the engine is idling, what would cause that> surely it should only boil under hard use like drifting as you said
Change your oil,heat cycles lower the boiling point and the oil gets burnt. What your seeing at idle is the fluid moving through the reservoir by the pump
